Date/Time: Sat, 03 Oct 2026 08:58:41 +0000
ACSIL Index Function
View Count: 1751
| [2015-03-30 16:56:48] |
| Johnny - Posts: 99 |
Hello, ACSIL provides the sc.GetHighest() and sc.GetLowest() functions in order to calculate the highest and lowest values over a specified number of bars. However, is there a function that calculates the corresponding index for the highest and lowest values?
| [2015-03-30 17:32:04] |
Do you mean gets the index? That is easy enough for us to add.
| [2015-03-30 17:56:11] |
Exactly, a function that returns the index, something like sc.GetHighestIndex().
| [2015-04-01 05:25:20] |
These will be added to the next release. Check the What is New Page for details.
