Date/Time: Fri, 18 Oct 2024 03:51:47 +0000
What happened to chart file selection?
View Count: 888
[2015-03-30 14:47:26] |
arrow - Posts: 52 |
I just updated to 1242. The new chart file selection only allows me to pull charts from the data folder itself. I have charts in different folders how do I get to those charts now? |
[2015-03-30 15:32:27] |
ertrader - Posts: 670 |
Yes..agree..see this link too. opening chartbooks in SC 1241 |
[2015-03-30 16:20:08] |
arrow - Posts: 52 |
Thanks for the link to the previous thread. |
[2015-03-30 17:31:34] |
We are working on adding this capability. Should be out later this week along with search capability. There will be many enhancements.
[2015-04-01 14:05:07] |
The folder selection option is working well...thanks for adding back in V1243
[2015-04-01 17:50:27] |
OK thanks.
