Date/Time: Sat, 21 Dec 2024 17:49:15 +0000
VbP: Number Of Periods Back To Reference does not work with 1 day and Sun/Mon
View Count: 1092
[2015-03-30 01:02:09] |
i960 - Posts: 360 |
Using a VbP of 1 day with back-reference of 1 day results in a Sun or Mon plot trying to use Saturday/Sunday data that isn't there. I haven't figured out exactly what day it's trying to use internally, but in order to see Friday's VbP I had to set it to reference 3 periods back. This of course wrecks all the other days it's being used on. It's not days that matter, it's sessions. |
[2015-03-30 04:43:30] |
This is true. The initial implementation of this feature does not automatically skip periods where there is no data. Eventually this will come.
[2015-03-30 12:49:53] |
Bango - Posts: 76 |
That's good! Also a "last X sessions" profile feature would be highly appreciated!
