Date/Time: Sun, 08 Sep 2024 00:44:30 +0000
TPO + VbP: Strange behavior seen when VbP study precedes TPO study
View Count: 800
[2015-03-28 19:55:51] |
i960 - Posts: 360 |
I don't quite remember how one of my charts ended up with this configuration of studies, but I'm documenting it in case it someone else comes across it or it might be an underlying issue. If the VbP study precedes the TPO study, they'll appear to plot fine at first, but when changing bar width (zoom in/out), the VbP study will be offset from the TPO charts until the chart is shifted back and forth (left/right arrow). Reverting the order to TPO as the first study and VbP as the second fixes the behavior. |
[2015-03-28 20:13:14] |
This has been corrected in the latest prerelease of Sierra Chart.
