Date/Time: Sun, 08 Sep 2024 00:26:13 +0000
VbP: Minor doc bug
View Count: 806
[2015-03-28 19:53:20] |
i960 - Posts: 360 |
http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#Color These two sections have the same text which looks like a copy/paste issue (high vs low, but both use high in the description): Value Area High-Value
This Subgraphs is only used to contain the value area high values for each Volume Profile for each bar in the chart. It is not used for Color, Line Style or Width settings. Value Area Low Value This Subgraph is only used to contain the value area high values for each Volume Profile for each bar in the chart. It is not used for Color, Line Style or Width settings. Plural vs singular is probably another issue. Also, I still cannot understand what these SGs actually refer to based on the description. I realize they're related to the value area high and low but I cannot understand how they're used as a sub-graph. |
[2015-03-28 20:44:49] |
The documentation will be corrected. Thank you for pointing that out. These particular subgraphs contain data only and are not visible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
