Date/Time: Sun, 04 Oct 2026 13:37:43 +0000
Running a 2nd Sierra instance
View Count: 1063
[2015-03-28 17:17:30]
Leo33 - Posts: 73
If I want to run a 2nd Sierra instance on a 2nd PC, do I need a 2nd licence and feed?
Can I relay the feed from a 1st Sierra instance?
[I'm currently running 2 Sierra's on the same PC and this would be a 3rd]
[2015-03-28 20:18:27]
For running Sierra Chart, just use the same Sierra Chart account and you can run another one at the same time.
As far as the particular data feed goes, this is a different question and you have to contact the provider of the data feed to see if 2 connections are allowed at the same time.
