Date/Time: Sun, 08 Sep 2024 00:22:57 +0000
Crude Continuous contract problems
View Count: 833
[2015-03-28 12:27:16] |
trader46 - Posts: 18 |
There are holes in continuous CL data using transact feed..anyway I can get this fixed
[2015-03-28 15:05:12] |
ktfroy - Posts: 85 |
I had this issue earlier. https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading |
[2015-03-28 16:12:51] |
Thanks, I have tried this and it did NOT resolve the issue
[2015-03-28 20:10:02] |
Precisely what is the problem? And in most cases when re-downloading data does not resolve the problem it is because the procedure was not done exactly as documented: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
