Date/Time: Mon, 05 Oct 2026 19:58:45 +0000
Technical notice
View Count: 1195
[2015-03-28 10:06:12]
User27439 - Posts: 11
I keep receiving this notice:
"Technical Notice: To be able to connect to Interactive Brokers Trader Workstation from this version of Sierra Chart, requires TWS version 9392 or higher.
It can be downloaded from here."
I downloaded it but it keeps popping up, otherwise everything looks ok.
thanks for your help
[2015-03-28 19:56:57]
i960 - Posts: 360
As a TWS user I also kept seeing this - even with a TWS version well past that. I simply selected the "don't show again option" to make it go away.
[2015-03-28 20:12:01]
This notice will always show no matter what version of TWS you are running. You do need to enable the option "Do not show this again".
