Date/Time: Fri, 11 Sep 2026 02:00:33 +0000
SC v1241 Open Chart Dialog Suggestion
View Count: 1101
[2015-03-27 23:28:05]
User80177 - Posts: 29
I've just upgraded from SC v1211 to 1241.
The new Chart Open Dialog window seems to be an unnecessary modification. The window is too small and needed to be scrolled back and forth to view the full chart name and details and it does not have a search or filter function.
The previous dialog is great and is so much better than the new one and I propose that it is reinstated.
Date Time Of Last Edit: 2015-03-27 23:29:56
[2015-03-27 23:29:49]
We are definitely not going to put back the old one. We can add search capability and make the list box larger.
[2015-03-28 00:03:21]
Please also realize, that the new File/Save dialog is new and certainly over time it will be enhanced.
We have made an immediate change now to make the list box wider. This will be in the next release we are putting out now.
And we will add search capability. We are also going to add the capability to change the folder in the case of when opening a chartbook and other cases where a folder change is allowed.
