Date/Time: Sun, 08 Sep 2024 00:43:16 +0000
Premiums
View Count: 1215
[2015-03-27 19:28:10] |
User28696 - Posts: 7 |
Hi, I used find a symbol and i saw the premiums listed but the chart won't load for any of them. What am I missing? thanks |
[2015-03-27 23:12:06] |
These are only available with a direct account and when using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed More specific information can be found at the bottom of this page: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#StockIndexPremiums Here is information about a direct account: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-27 23:27:36
[2015-03-28 21:49:32] |
i960 - Posts: 360 |
BTW: I think if one already has exchange data for both cash indexes and futures, they would also be able to make such a chart by simply using a difference or ratio bar overlay with the two symbols (e.g. ESM5 - $INX). The "premiums" section probably just makes it straightforward with less "manual labor."
