Date/Time: Sun, 08 Sep 2024 00:37:17 +0000
Log - error message
View Count: 1466
[2015-03-27 18:11:40] |
User28682 - Posts: 233 |
I have sent a copy of the log as I am getting an error message every few minutes. Its "windows error code 12002".
Date Time Of Last Edit: 2015-03-27 18:15:06
[2015-03-28 21:43:40] |
Not totally sure what the HTTP request is what is causing that. If you select File >> Disconnect, do you still notice it? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
