Date/Time: Sun, 08 Sep 2024 00:39:24 +0000
I have a funded trading account; billing question
View Count: 1000
[2015-03-27 16:33:24] |
User566564 - Posts: 6 |
I have a funded trading account with tradeking broker. I only have an interest in Sierra Chart monitoring the charts in real time for oil futures. Such as WTI crude oil, CL* which falls I believe under NYMEX. I have read the posts provided. I would like to please know with a simple direct answer how much I would have to pay if I want: 1) The $40.00 Package service for charting tools. 2) Live real data for WTI Oil, CL* Just the pricing on those two things. Should be a simple reply. Then all I will have left is to set up my payments. Thank you, |
[2015-03-27 17:32:15] |
No, it is not a simple reply due to exchange rules. Through Trade King, what backend trading platform are you using through them? Refer to this page for the supported list: https://www.sierrachart.com/index.php?page=doc/data.php#Services If you want to know the cost without consideration of the above question, the cost would be about $270 a month. If we know the answer to the above question, the cost could be as little as 30 a month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-27 18:12:30] |
Thank you for that guidance, What I found from tradeking was that they use an "API" they said, and they further commented " API It is commonly used by those who wish to write their own software to be used in connection with our trading platform." If this does not serve of use what I can do is wait for next month when I open a second account with Gain Capital Group who has the OEC backend mentioned in your list. |
[2015-03-27 18:26:24] |
Yes, the best thing to do is wait until next month when you have your OEC account and the cost will be dramatically less. Sierra Chart does not use the Trade King API. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
