Date/Time: Tue, 26 Nov 2024 05:22:00 +0000
[User Discussion] - is there is a stop and reverse order type?
View Count: 2008
[2013-05-30 05:59:09] |
User32496 - Posts: 26 |
if i am long and stop was triggered, i want to get into short all "new" trade stops and targets are the same as before any advice? thanks |
[2013-05-30 20:58:30] |
No, this is not currently supported. You could do this in an automated way by using the Spreadsheet System for Trading study: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-30 21:13:42] |
M5amhan - Posts: 468 |
if you are long 10 contracts and want to stop and reverse just have your sell stop size set to 20 and you will be stopped out and short 10 contracts.
[2013-05-31 21:10:28] |
Sawtooth - Posts: 4120 |
Take a look at this: Feature request: 1 click trade to desired position |
[2013-06-02 08:48:15] |
the idea was to have a reverse position with the same stop and take profit as were in the original trade. |
