Date/Time: Sun, 08 Sep 2024 00:40:30 +0000
No data for NYSE advance and declines ratio
View Count: 931
[2015-03-27 16:01:46] |
William F - Posts: 6 |
I am trying to work with the NYSE Adv issues - Dec issues and the NYSE Adv volume - Dec Volume (intraday). They are listed in the "Find Symbol" box as "$NSHF and $NVLF". When I enter that into the Chart Settings window there is no date range shown in the "Date range in File" and I am not able to make any entry in that box. Please advise on how I may remedy this. Thanks. |
[2015-03-27 17:22:29] |
Those are not the correct symbols. Refer to the correct market statistics symbols on this page: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
