Date/Time: Thu, 24 Sep 2026 03:15:43 +0000
Bug In Volume By Price When Switching The Draw Mode
View Count: 1437
| [2015-03-27 00:33:25] |
| cmet - Posts: 743 |
This is just something I came across that I thought I'd point out. When you add Volume Profiles to a chart and then switch them to POC,VAH, VAL Lines Only, none of the draw types are available. Only "Visible" and "Ignore". The only way to gain access to the draw types drop down list is to click "okay" to quit out of settings and then relaunch the study settings. Here is a video showing what I mean: http://tinypic.com/player.php?v=vnczyq%3E&s=8#.VRSlQZOKhjM |
| [2015-03-27 01:05:51] |
We do know about this.
