Date/Time: Sun, 08 Sep 2024 00:36:19 +0000
SecondsPerBar for remote chart
View Count: 857
[2015-03-26 17:51:44] |
onnb - Posts: 662 |
Is there an api to get SecondsPerBar for a remote chart? If not, can you add something like GetChartSecondsPerBar(int ChartNumber)? Date Time Of Last Edit: 2015-03-26 23:54:25
[2015-03-27 03:36:39] |
We are very hesitant to add this. It has to be thought through more comprehensively and implemented properly.
[2015-03-27 03:47:39] |
onnb - Posts: 662 |
Understood - have a work around for now and this is not urgent. It would help in general to have something like sc.GetChartDetails(chartNumber) which returns a "ChartDetails" structure chart details includes the symbol, time frame, bar types, value format, etc. Its understood that this needs to be thought out - not urgent but would be useful in many cases. |
