Date/Time: Sun, 08 Sep 2024 00:09:41 +0000
Chart values
View Count: 816
[2015-03-26 16:39:53] |
User82486 - Posts: 43 |
The values of the studies on my chart are not visible. The value AREA i REFER TO IS USUALLY AT THE RIGHT SIDE OF THE REGION. HOW DO i MAKE THEM VISIBLE. fRED |
[2015-03-26 16:47:41] |
Refer to the Name and Value labels documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#NameValueLabels These settings are in the Study Settings window: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
