Date/Time: Sat, 12 Sep 2026 09:35:41 +0000
set up
View Count: 1207
| [2015-03-26 14:14:04] |
| User23979 - Posts: 1 |
I am setting up Sierra Charts, I have had a trial previously. I cannot down load the current version of SC, all goes well until the install.Gets about 40% the errors out. Also I cannot connect to data feed. (Bar Charts) I have completed all funding requirements. Where do I go from here? Best regards Marv Troyer |
| [2015-03-26 15:33:25] |
1. We can see that you are running the latest version of Sierra Chart. 2. Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support |
| [2015-03-26 16:41:46] |
We see you have activated the Sierra Chart Exchange Data Feed. To use this data feed, follow the instructions here beginning with step 12: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Do not select the "Barchart" Service in Sierra Chart. It will not work properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
