Date/Time: Sun, 08 Sep 2024 00:19:33 +0000
Chartbook freezes. Can I duplicate charts to new cbt outside of Sierra?
View Count: 833
[2015-03-26 10:02:46] |
phaedonk - Posts: 352 |
Not sure why it keeps freezing. No special studies, and no CPU usage spike, its around zero actually, RAM usage is 70MB. It started after an abrupt PC shutdown. I want to copy all charts with their drawings to a new chartbook, as I see no other solution, but it seems impossible to do it while Sierra is running, the whole system is crawling (with a minimum CPU usage and RAM at 50%, now that's strange!). Can I edit the cht file with an editor to achieve what I want? Is there any other way? Thank you. |
[2015-03-26 10:25:14] |
It seems the problem is with a data file and not with the chartbook, as I moved all data files outside of the Data folder and the chartbook is behaving normally with the data being re-downloaded. The re-downloading of course is a problem with IB pacing violations. Maybe, I'll overwrite each file with the old bigger one and see what happens?
