Date/Time: Mon, 30 Dec 2024 18:16:45 +0000
Order modification error when in chart trading mode
View Count: 929
[2015-03-25 23:44:49]
flyboy615 - Posts: 56
I can seem to reproduce this error pretty consistently. Using a stop all triggered trailing stop with 2 targets and one common stop, once the first target gets hit the error is either caused by the BE stop triggered by group 1 or the trailing stop triggered a fixed offset trigger. I've included the twconfig file which will make it clearer. This seems to happen in both simulated and transact's simulated live modes.
Steps to reproduce...
in a down trend set a sell stop limit using the attached config file; once the first target watch the trade service log for the following error:
Order Modification Error: Order is not in a Working state. Order cannot be modified . Internal Order ID: 152647. Service Order ID: 152647 | 2015-03-25 19:32:38 *
If you need anything else please let me know.
Rob
Private File
[2015-03-26 17:03:55]
We will be checking on this.
[2015-03-31 07:09:55]
We cannot duplicate this problem but we get a sense of why it could occur. But it is not 100% clear.
We need to understand what is the ultimate consequence of this. Is the stop order not properly adjusted? Or is it merely just an error message?
There could be scenarios where the error message is simply normal because of circumstances which cannot be handled to avoid the error to begin with. Or at least not easily recognized.
It is possible that the order has been queued for modification but it has been canceled or filled.
