Date/Time: Sun, 08 Sep 2024 00:04:31 +0000
Default Worksheet will not update to current symbol expiration
View Count: 816
[2015-03-25 20:48:58] |
brando - Posts: 14 |
Chart 1 posts correctly to default worksheet 1. If I duplicate chart to 2,3,4 etc. the chart duplicates correctly with current symbol expiration and price but the default worksheet does not. The worksheet symbol will be correct on the default worksheet but the expiration and prices will be previous expirations and prices, some going back more than a year.
[2015-03-26 01:58:36] |
This is not very clear for us. And what you are describing is an impossibility. Make sure you are looking at the correct Spreadsheet and the correct Sheet within the Spreadsheet. Check the Spreadsheet Study Settings on the chart to know exactly what these are. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-26 03:27:06] |
Thank you. I had incorrect chart data output settings. Working ok now.
