Date/Time: Sun, 08 Sep 2024 00:21:32 +0000
Full Stochastic Charting Tool?
View Count: 1744
[2015-03-25 20:19:46] |
User566564 - Posts: 6 |
Hello, I am not seeing a Full Stochastic charting tool. Has anyone noticed this available? Thank You |
[2015-03-26 01:50:47] |
There are several stochastic studies found in Analysis >> Studies. Nothing named "full stochastic" though. First we have heard about that.
[2015-03-26 15:46:00] |
The Full Stochastic Oscillator is a fully customizable version of the Slow Stochastic Oscillator. Users can set the look-back period, the number of periods to slow %K and the number of periods for the %D moving average. The default parameters were used in these examples: Fast Stochastic Oscillator (14,3), Slow Stochastic Oscillator (14,3) and Full Stochastic Oscillator (14,3,3). Full Stochastic Oscillator: ◾ Full %K = Fast %K smoothed with X-period SMA ◾ Full %D = X-period SMA of Full %K Thank you for the prior reply :) |
[2015-03-26 15:48:10] |
If you would like to see how this tool works visit netdania.com under studies section. Would be great if Sierra had it. I'd def join at that point :)
[2015-03-26 16:27:47] |
Sierra Chart does have this and it is called the "Slow Stochastic" study. Here is the documentation: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s22 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-26 16:29:08
