Date/Time: Sun, 08 Sep 2024 00:15:02 +0000
Drawn Horiz Ray
View Count: 840
[2015-03-25 19:22:49] |
SgtJ - Posts: 154 |
Had a H.ray drawn from about 1 wk. Today I "cut drawing here" and it caused a large increase in cpu usage, causing a noticeable lag when dragging chart scaling. Used the 2nd down draw style (dash), and a width of 2. SC version 1202, win7 pro.
[2015-03-25 21:43:48] |
This may have already been fixed. Update Sierra Chart with " Help >> Download Current Version". Let us know if you still have the problem.
