Date/Time: Fri, 18 Oct 2024 03:19:35 +0000
autocentering DOM turn off ?
View Count: 868
[2015-03-25 13:52:19] |
User52239 - Posts: 13 |
Is there a setting to have autocentering turned off on the DOM ? shane |
[2015-03-25 17:58:25] |
Yes. Right click on the column of numbers on the Trade DOM and select Scale Range: Constant Range.
