Date/Time: Fri, 22 Nov 2024 19:01:35 +0000
KD-slow and Stochastic-slow
View Count: 1972
[2013-05-30 01:33:53] |
User62256 - Posts: 3 |
Hello SC team, There is a question for you! I noticed that there are two studies KD-slow and Stochastic-slow. I plotted them on one chart and found there is zero difference between them! Where am I wrong? If you dont mind,would you please tell me the difference between KD-slow and Stochastic-slow? Thank you ! ZK |
[2013-05-30 07:16:06] |
We had forgotten those were in there. These are just other names for the Stochastic studies that are familiar to some. There is no difference.
