Date/Time: Mon, 28 Sep 2026 09:19:46 +0000
How do I track down an old alert to disable it
View Count: 1293
| [2015-03-25 03:47:59] |
| User29511 - Posts: 19 |
I have an old alert keeps going off during trading but I can't identify where it is coming from. Is there a way to track it down? I have gone individually through all the charts I currently have automatically opening each day (about 60) - but no alert conditions are visible in them. If Alert 1 is selected in the chart window - but no formula for the alert is present - will that still sound off an alert? Do alerts continue to function even if the chart and chart book they are applicable to isn't open? Thankyou in advance. |
| [2015-03-25 03:55:56] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails68.html If Alert 1 is selected in the chart window - but no formula for the alert is present - will that still sound off an alert? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-25 03:56:18
