Date/Time: Sun, 08 Sep 2024 00:20:43 +0000
[User Discussion] - Zig-Zag bug in Calculation Mode 3
View Count: 1241
[2015-03-24 21:07:54] |
User68474 - Posts: 201 |
When using Mode 3 in Zig-Zag Study with Setting for High-Low Input Data set to "Last", I notice that if the swing high or low has two or more consecutive bars with the exact same close, the Zig-Zag line peaks/valleys at the close of the first of the bars. The apex should shift to the close of the last bar before changing direction. This is very important if a trader is using, in addition, Zig-Zag Accumulated Volume. It renders the Swing Volume innacurate as it adds the volume of the last bar(s) which follow the first of the swing high bars (again, assuming they all have the same close) to the next/following Swing instead of accumulating it as part of the existing(soon to be completed/reversed swing.
[2015-03-25 18:10:36] |
We cannot change this. This is just how it is. This study is immensely complicated as it is and we are certainly not going to complicate it further by trying to support this. We would not even consider it. Also when you are using the Last and not the High/Low you are going to have inconsistencies with this study between real-time updating and a full recalculation and we cannot help with those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-30 09:02:17
