Date/Time: Sun, 22 Dec 2024 02:49:09 +0000
Volume Profiles
View Count: 928
[2015-03-24 20:58:24]
pismo10 - Posts: 159
Using 1241, DTNIQ, 1.25 range chart with @ES#. When I draw a volume profile on the chart from say start bar to end bar it jumps to start bar-1 bar after the next tick of data comes in. So for a moment it is correct and then moves by itself.
Thoughts?
Thanks,
Steve
[2015-03-25 18:11:47]
Follow the instructions here to set Sierra Chart for a tick by tick data configuration:
https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php
See if that corrects the problem.
[2015-03-26 16:46:00]
Unfortunately, no help.
[2015-03-26 17:01:45]
We are checking on this.
[2015-04-04 16:39:35]
Al SC Developer - Posts: 434
This should be addressed in the next version.
