Date/Time: Fri, 25 Sep 2026 19:51:45 +0000
TPO Graphics
View Count: 1199
| [2015-03-24 19:37:18] |
| User94740 - Posts: 333 |
Hi SC, every time I switch from a TPO chart to another chart and then back, the TPO and VbP graphics are out of sync and then I scroll and it goes back in to sync. I never had this problem before and am using the same laptop with SC for the past 3 years. Has something changed?
| [2015-03-24 19:39:33] |
please excuse, I have uploaded a copy of the chart http://www.sierrachart.com/image.php?l=1427225921375.png |
| [2015-03-26 03:34:47] |
We are looking into this problem.
