Date/Time: Sun, 08 Sep 2024 00:39:40 +0000
Dynamic memory
View Count: 1038
[2015-03-24 18:18:32] |
WarriorTrader - Posts: 245 |
Hello, Your documentation on dynamic memory has been very helpful. I noticed that instead of using delete [] you instead just use delete. Do you have delete overloaded or do you need to use the delete [] command? Thx, -WT https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#DynamicMemoryAllocations |
[2015-03-27 19:07:03] |
Apparently with Visual C++ delete [] does not need to be used but it should be. The documentation has been updated with the current code which uses the AllocateMemory and FreeMemory functions of ACSIL.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-27 19:10:33
