Date/Time: Fri, 22 Nov 2024 18:33:51 +0000
Drawing Tools
View Count: 1620
[2013-05-29 23:34:43] |
AkTrader - Posts: 13 |
I've noticed that some drawing tools appear behind candles and some appear on top of candles. Where is the setting to change this? Sometimes I like to see volume profiles behind the candles and sometimes I like to see them in front of the candles. Same with trend and horizontal lines. Thanks, Jeremiah |
[2013-05-29 23:48:26] |
The settings for this are in Chart >> Chart Settings >> Advanced Settings. In the case of Volume Profiles this is controlled through the Study Settings for the Volume by Price study on the chart. There is a study input to display profiles above or below the price bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
