Date/Time: Sat, 13 Sep 2025 04:29:17 +0000
creating alert ?
View Count: 1031
[2015-03-24 04:37:16]
User52239 - Posts: 13
How can I add an arrow to a simple alert of a crossover ?
It seems I can only add a sound with the alert.
I also see the color bar based on alert.
Is there any way to create a visual alert without having to use the spreadsheet system for alert ?
e.g. I would like to add an up or down arrow on a crossover.
shane
Date Time Of Last Edit: 2015-03-24 05:03:28
[2015-03-25 01:12:43]
Sawtooth - Posts: 4263
Use the Color Bar Based On Alert Condition study, and set the Draw Style to your choice. If you want both up and down arrows, you'll need 2 instances of the Color Bar study.
BTW, the formula will need to reference the ID# of the study on which you want the alert.
