Date/Time: Sat, 21 Dec 2024 17:52:28 +0000
Drawings Don't Follow Back Adjustment
View Count: 998
[2015-03-24 04:09:25]
User158367 - Posts: 4
I rolled over ESH5 to ESM5 & my drawings are off by the contract difference. (it appears) I am using Version 1241 & Continuous Futures Contract - Date Rollover, Back Adjusted. (Historical Charts have the same problem)
I went to Chart >> Reload and Recalculate & the problem remained. I was then told by my broker to delete & download data & this also did not solve the problem. I have never had a problem with my drawings after rollover before.
Please advise.
[2015-03-24 04:22:11]
You will need to manually adjust them through Tool >> Manage Chart Drawings Window >> Adjust.
[2015-03-26 02:14:11]
Thank you for the solution.
Am I going to have to do this with every rollover?
I have not had to in the past.
Thanks.
[2015-03-26 02:27:00]
Yes!
[2015-03-30 00:06:40]
You've got to be kidding! What used to be an automatic operation has now devolved into a manual mess? Please keep in mind that many users have multiple drawings on continuous charts extending back across several contracts (e.g. long term trend lines and the like). Manual readjustment of all these drawings on multiple charts is a nightmare. Sierra Charts used to do this automatically, why the devolution? Can this be fixed?
[2015-03-30 04:41:04]
This was never automatic and would never be made automatic. You can select multiple drawings and adjust them at once.
[2015-03-30 19:18:27]
Would it be possible to program to be able to select all drawings from a single symbol & adjust them all rather than having to adjust each chart ? (I have as many as 18 on a single symbol)
