Date/Time: Sun, 08 Sep 2024 00:24:10 +0000
[User Discussion] - Set a daily loss limit
View Count: 1613
[2015-03-23 12:50:24] |
User14682 - Posts: 83 |
I currently use an automated trading system utilizing the sierra chart spreadsheet. How do I set a daily loss limit of $900 per day?
[2015-03-23 15:14:12] |
Sawtooth - Posts: 4083 |
Reference a sum of J10 and J45 in your entry and/or exit formulas. Entry: $J$10+$J$45>-900 Exit: $J$10+$J$45<-900 |
[2015-03-23 18:23:49] |
We have also responded to this here: Set a loss limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-27 12:24:13] |
=OR(AND(AA3<AM3,AA4>AM4,AM3<AG3),AND(AA3<AG3,AA4>AG4,AG3<AM3,AND($J$10+$J$45<-900)) enclosed is my exit strategy combined with what you sent and it says it is invalid? |
[2015-03-27 12:58:32] |
Try this: =OR(AND(AA3<AM3,AA4>AM4,AM3<AG3),AND(AA3<AG3,AA4>AG4,AG3<AM3),$J$10+$J$45<-900) |
[2015-03-27 14:21:22] |
LOOKS LIKE ITS WORKING.. THANKS
