Date/Time: Thu, 24 Sep 2026 19:35:20 +0000
Plotting POC, VAL, VAH Lines Underneath Volume Profiles on Same Chart?
View Count: 1418
| [2015-03-22 18:53:59] |
| cmet - Posts: 743 |
I'm trying to plot both POC, VAL, VAH Lines and Volume Profiles on the same chart using 2 separate Volume By Price studies. I want to use Fill Rectangle Top/Bottom as the fill type on the POC and VALH Lines. I want these to be underneath the Volume Profiles. However, no matter what I try in terms of display order/draw underneath, the POC and VAL lines always plot above the profiles (covering them up). The only workaround I've found is to: 1. Make the price bars invisible (blank) 2. Select "display above price bars" for the Volume Profiles 3. Create another chart of the same time frame 4. Use Study/Overlay to plot the price bars on top of everything else. The other is to use the Transparent Rectangle options but this makes the chart very difficult to use visually. Is this the only way to do this? Date Time Of Last Edit: 2015-03-22 18:55:24
