Date/Time: Sun, 08 Sep 2024 00:15:42 +0000
No option for Name/ Value Label in Study Price Overlay
View Count: 1201
[2015-03-22 16:22:43] |
nicktrader - Posts: 699 |
I'd like to see in the DOM the Daily Pivots Points and for that purpose I am using the Study/ Price Overlay. As you can see in the screenshot the Labels for Name and Value are on. In the study you have the options for color and Draw Style but not for the Labels. In my case I'd like to see only the name label and the horizontal align on LEFT and the value label should be off. Is there any way? |
[2015-03-26 04:12:28] |
You need to change this on the source study being referenced.
[2015-03-26 07:17:38] |
I know but what if I'd like different views. On source for instance with name an price levels and on the other chart without any. From my point of view it should be more flexible.
