Date/Time: Tue, 22 Sep 2026 14:02:46 +0000
Renko Shift / Median Renko
View Count: 1884
| [2015-03-21 22:11:40] |
| knowle - Posts: 25 |
Although Sierra has standard Renko I have not been able to locate a Renko bar shift feature. The shift feature allows each Renko bart to be shifted relative to each other. A standard Renko would have a shift of 100%. The ability to shift the bars, say 50%, 25% or any other preference, give greater control and precision. Search engine images will provide visual examples. 1. If this feature is available in Sierra can you kindly advise accordingly. 2. If not, would there be a possibility of updating the present standard Renko to include bar shift. Gad, over worked ! Yes, this feature is available in Sierra - called Flex Renko - http://www.sierrachart.com/index.php?page=doc/doc_RenkoCharts.html Date Time Of Last Edit: 2015-03-21 22:37:49
