Date/Time: Mon, 14 Sep 2026 15:41:39 +0000
Lock symbol in chart
View Count: 1504
| [2015-03-21 12:09:05] |
| phaedonk - Posts: 352 |
Can this be done? i.e. I want EURUSD in a chart and no way for it to be changed, other than by changing it in the Chart Settings window. There are numerous times that I managed to change the chart symbol, by mistyping and hitting enter. For example, this can happen if I type 11w (instead for 11s- eleven seconds) and hitting enter. It's very frustrating and can be dangerous if it happens at the wrong time.
Date Time Of Last Edit: 2015-03-21 12:09:51
| [2015-03-21 22:01:14] |
You need to disable Global Settings >> General Settings >> Support Symbol Entry from Chart Window.
