Date/Time: Sat, 21 Dec 2024 17:43:10 +0000
Unable to see Chart Values/Crosshair Color w/Black Background
View Count: 1263
[2015-03-20 18:21:14]
User17836 - Posts: 12
As above, the color of the tool is black and is not possible to view with a black background without the lines enabled. The only options in the global tool settings are for the lines and not the crosshair itself. Any remedies?
[2015-03-20 18:23:30]
This is a difficult question because the Pointer is what you are referring to and that is something which is part of the operating system. You may be able to get this to work by changing Pointer through the Windows Control Panel Mouse >> Pointer settings.
[2015-03-20 18:33:34]
No - pointer is actually white. See attached image for the crosshair.
imagecrosshair.jpg / V - Attached On 2015-03-20 18:33:17 UTC - Size: 104.61 KB - 363 views
