Date/Time: Fri, 18 Oct 2024 06:16:40 +0000
graphical change
View Count: 791
[2015-03-20 16:10:52] |
EuropeanTrader - Posts: 290 |
hi is there a way I can decrease this white space? thx |
[2015-03-20 17:16:04] |
From what it looks like we would not expect that amount of space to be there to begin with. So we are not sure what is causing it.
