Date/Time: Fri, 18 Oct 2024 06:16:40 +0000
Copying Ray to Chart #
View Count: 796
[2015-03-20 14:55:42] |
infpz - Posts: 826 |
Can you please take a look at the attached file? I drew the line on the right hand chart, and asked that it be copied onto the left hand chart. Can you tell me why the line looks so different on each one? It only seems to be affect the 6E chart. At 10:30, the time roughly indicated by the blue arrow, the market is well above the line on the right hand chart, and on the left hand chart, it is way below the market. Thanks! PZ |
[2015-03-20 16:03:02] |
Refer to this section here: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html#RayExtendedDrawings If there still is a question about this, then we need an explanation as to why it should look different than it is. And in any case, we are certain the result you are seeing is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-20 16:04:13
