Date/Time: Sun, 08 Sep 2024 00:44:54 +0000
[User Discussion] - Set a loss limit
View Count: 1255
[2015-03-20 13:37:11] |
User14682 - Posts: 83 |
I am interested in setting a loss limit on my account? I run an automated system and I dont want to loose more than $1000 per day
[2015-03-20 17:12:56] |
Is this an automated trading system you are running in Sierra Chart?
[2015-03-20 22:14:15] |
Yes... it is a system utilizing the sierra chart spreadsheet..
[2015-03-23 18:22:57] |
Therefore, you can use the Daily Profit/Loss and the Disable Auto Trading cells to accomplish this: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#CellJ45 https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#DisableAutoTrading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-27 11:55:39] |
do you know a basic code to implement this?
[2015-03-27 12:19:55] |
Sawtooth - Posts: 4083 |
See this response: Set a daily loss limit |
