Date/Time: Fri, 18 Oct 2024 06:17:55 +0000
linking DOM
View Count: 1585
[2015-03-20 13:16:04] |
User52239 - Posts: 13 |
Hi Is there any way to link DOM to quoteboard or another chart like you can do with other charts ? shane |
[2015-03-20 16:50:13] |
Yes. Chart linking works with Trade DOM windows since they are charts. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartLinking You can set the linking options through Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
