Date/Time: Fri, 18 Oct 2024 06:17:14 +0000
DOM - market depth - How to change data feed for DOM?
View Count: 835
[2015-03-20 12:43:19] |
User39696 - Posts: 6 |
Hello, I am using 2 data feed, for trading IB and for ordeflow analysis IQ feed (in one chart). I do not pay to IQ feed for market depth. And if I want to show in DOM market depth nothing is happening. There could be a problem with data feed (it can use IQ feed wit no market depth data) How can I change data for DOM from IQ feed to IB and still have tick data for my orderflow analysis in one chart where I trade? Thank you very much, Martin. |
[2015-03-20 17:14:35] |
You need to open a chart or Trade DOM which does not use data from IQ Feed, in the instance connected to Interactive Brokers, to access the market depth data from Interactive Brokers. So it must be a separate chart. There is no other possibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
