Date/Time: Thu, 03 Apr 2025 07:25:39 +0000
[Locked] - Trades Executed at Bid/Ask
View Count: 7003
[2013-08-15 02:06:32]
What started out as seemingly a somewhat simple implementation to perform a basic function has now become feature with many enhancement requests. We do thank you all for all of these additional postings, but we cannot spend further time on this. We have many other higher priorities. This will have to be reviewed probably sometime later in the year.
At this time there will not be further review. We will put together clear documentation on how the functionality currently works.
Date Time Of Last Edit: 2013-08-15 02:06:57
[2013-08-15 02:56:51]
joshtrader - Posts: 504
I think the implementation currently is very good, and thanks for doing it. I would like to thank you for all the work you have done with the DOM over the last year. It has become very usable and this recent addition only adds to that.
[2013-08-15 03:03:52]
ganz - Posts: 1048
joshtrader
+1
[2013-08-24 06:06:42]
eagle - Posts: 92
Would you please post a link to this documentation. Thanks.
[2013-08-24 07:34:02]
Yes. Here it is:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalTradeSettings.html#ChartDOMColumnDescriptions
[2015-02-28 15:03:06]
Bridget - Posts: 3
Under Globabl settings>customize tradedom columns> I added the Recent Bid Volume and Recent Ask Volume
When I go to global settings>tradeDOM Recent Ask and Recent Bid the Enable button is grayed out.
Do you know why this is grayed out and how do I fix this. I'm using Rhithmic data feed if that helps.
[2015-02-28 23:52:18]
We do not know what button you are referring to. There is not a button on the menu you are referring to. Start a new thread with this link:
https://www.sierrachart.com/SupportBoard.php?do=NewThread&ForumID=0
And be more clear as to specifically what you are referring to.
