Date/Time: Fri, 18 Oct 2024 06:16:54 +0000
Continuous YM chart
View Count: 883
[2015-03-18 14:21:20] |
arrow - Posts: 52 |
I recently changed my YM chart to the M contract month. The day chart is set to be continuous volume based rollover. Once it rolled over the continuous contract went away and will only display current month. On another PC I have the YM up with all the same settings and the chart displays the continuous contract as it should. |
[2015-03-18 19:39:20] |
See: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-20 01:48:47] |
arrow - Posts: 52 |
I tried what was listed. I even deleted the .dly and .scid files. It wont redownload the historical files after I delete them. I took all the YM data files from the other PC as well and it still wont display a continuous chart. Everything else I open and start new will display a continuous chart but the YM. The [CBV] is also up in the upper right hand corner of the chart after the symbol. |
[2015-03-20 03:45:23] |
Enable Chart >> Show Rollover Dates and post an image of the chart by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-20 13:44:18] |
arrow - Posts: 52 |
Chart
YMM15 YMM5-CBOT [CBV] Daily #11 2015-03-20 06_39_43.238.png / V - Attached On 2015-03-20 13:42:39 UTC - Size: 36.52 KB - 295 views Attachment Deleted. |
[2015-03-20 15:30:09] |
Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings After this is done, select Chart >> Reload and Recalculate. If you still have a problem, then do the following: -Restart Sierra Chart. -Open this one chart you have a problem with. -Post the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-20 15:41:10] |
arrow - Posts: 52 |
Symbol settings fixed it. Thanks |
