Date/Time: Sun, 20 Sep 2026 08:16:30 +0000
Tool Text
View Count: 1796
| [2015-03-18 11:38:22] |
| User96015 - Posts: 55 |
Hi, I need an information if it' s possible. I' m making a custom study and I would like to draw some horizontal line with a date as text below. I try in this way: Tool.Text = Coperture_Var_Data;
Coperture_Var_Data is a SCDateTime variable, but I' ve this problem in the complier:no match for 'operator=' (operand types are 'SCString' and 'SCDateTime') Thanks for answer. |
| [2015-03-18 16:17:38] |
You cannot directly assign a SCDateTime to a SCString. To work with text and strings refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#WorkingWithStrings SCDateTime documentation can be found here: Working with the SCDateTime Variables and Values For the location of examples see: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html#CodeAndExamples Sierra Chart Support |
| [2015-03-20 14:42:48] |
Thanks for the answer. I' ve another problem, I would have to add some days to a date excluding Saturday and Sunday. Is it possible? Thanks again and Bye. |
| [2015-03-20 16:12:52] |
Yes this is possible. Simply iteratively add the days but do not add the days when you encounter Saturday or Sunday. This function is available in ACSIL: inline int IsWeekend(int Date) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
