Date/Time: Fri, 22 Nov 2024 18:56:17 +0000
sc.Bid/sc.Ask
View Count: 1674
[2013-05-29 13:17:53]
Hendrixon - Posts: 130
In order to distribute load I use several instances of SC but only one instance pulls data.
I wrote a trading study that needs those values (current Bid/Ask prices) and found that they are only available on charts that use data on the SC instance that pulls the data.
On remote data file charts I get 0.00 values.
How can I pull the sc.Bid/sc.Ask values (or equivalent) when the study is on a chart with remote data file?
I have the "remote" instance connected to the feed and plot the DOM Graph fine, but get 0.00 for Bid/Ask.
Maybe they can be pulled with the DOM Access function?
(your code example shows only how to pull Volume)
Date Time Of Last Edit: 2013-05-29 13:18:45
[2013-05-29 20:42:58]
You need to enable this setting in General Settings:
http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#NonChartDataRemoteInstances
