Date/Time: Sun, 27 Sep 2026 20:02:53 +0000
Volume By Price Not Displaying Correctly (Disappearing/Flashing)
View Count: 2194
| [2015-03-16 03:17:33] |
| cmet - Posts: 743 |
What's happening: When I add the Volume By Price reference 1 bar ago, the study disappears and then flickers for the current bar. My settings: -POC, VAH, VAL Lines Only -Number of Periods Back to Reference: 1 -Multiple Profiles Fixed By Bar Length -Number of Bars: 1 When Number of Periods Back to Reference is set to 0, it plots fine. When it is set to 1, it only appears occasionally. You can pull up the Studies window for instance and keep clicking "Apply" and it will show up for about a second every time you do. Here is an image using a 0 (referencing the current bar): http://s10.postimg.org/51upd074p/current_bar.png And here it is referencing the previous bar - notice nothing is plotted: http://s10.postimg.org/witpo0j6h/1_bar_lookback.jpg The green is the VAH and VAL, the pink is the POC. In the second photo it is simply plotting the previous bar on the next bar - except not for the current bar. Here it is with 1 bar lookback and I click "Apply" really fast and take a snapshot, you can see the previous bar's value/poc plotted: http://s9.postimg.org/6epem3gov/clicking_apply.jpg Would like to fix this so that it is always visible. Since it's the previous bar, it should plot and stay static. Not sure if this is a bug or a setting somewhere. Here is a quick video that shows: -Referencing 1 bar back and clicking "Apply" -Referencing the current bar -Switching it back to referencing 1 bar back http://tinypic.com/player.php?v=dtnhk%3E&s=8#.VQZNho7F98G Date Time Of Last Edit: 2015-03-16 03:28:10
| [2015-03-16 16:57:20] |
| cmet - Posts: 743 |
Here's a chartbook with a chart showing the problem. |
| [2015-03-16 17:01:20] |
We are going to check on this today.
| [2015-03-17 22:20:41] |
| cmet - Posts: 743 |
Any update on this? Any solutions? |
| [2015-03-17 22:32:20] |
Yes. This has been solved. Update Sierra Chart to the latest release.
| [2015-03-17 22:55:41] |
| cmet - Posts: 743 |
Thanks a lot for fixing this so quickly. Much appreciated.
Date Time Of Last Edit: 2015-03-17 23:30:35
| [2015-04-29 09:42:41] |
| User888876 - Posts: 33 |
Good day, I have 30 min chart, I have dynamic VbP on its left side. How can I put separate VbP for a start of every new trading day? |
| [2015-04-30 04:48:11] |
You need to set the following inputs for the Volume by Price study: Volume Graph Period Type: Multiple Profiles Fixed by Time Time Period Type for Fixed by Time: Day Time Period Length for Fixed by Time: 1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-30 04:49:25
