Date/Time: Sat, 18 Jan 2025 19:23:23 +0000
UserContributedStudies.cpp
View Count: 1096
[2015-03-15 00:15:49] |
User22396 - Posts: 191 |
where can i find the UserContributedStudies.cpp? it used to be in the acs source folder but i cant seem to find it thanks |
[2015-03-15 01:20:20] |
We have the file but it does not contain all of the studies listed in User Contributed Studies. Is there a particular study from the user contributed studies list you are interested in? We will provide the source code for it.
[2016-02-10 14:56:29] |
cmet - Posts: 584 |
Can you please provide the source code for the ECIVwapBracketV1.4 and ECIVwapChannelV1.4?
[2018-02-26 20:57:40] |
NRGTrader - Posts: 351 |
18.02.26 I need the source data for MA Colour please or could you please recompile the UserContributedStudies.cpp to a 64-bit version. Thanks. |
[2018-02-26 22:08:26] |
We will build this as 64-bit. We also realize that post from 2016 has not even been answered, post #3. Although we have created this page here with all of the source code: User Contributed Advanced Custom Study System Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-26 23:04:30] |
Thank you, but I scanned that page link and I do not see "MA Colour" study listed.
[2018-02-27 01:11:59] |
Acro - Posts: 441 |
Further to post #6, I cannot see the source code for delta momentum there but I do recall it being on the website previously
